It is currently Fri Aug 22, 2025 2:13 am
 Post subject: Stuck saddles
PostPosted: Mon Jul 15, 2013 5:22 pm
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
I had 2 guitars ,a Larrivee and a Santa Cruz with stuck saddles over the weekend.I can usually get them un-stuck.Neither would budge even with a little heat .One of the guitars was a bridge re-glue and I still couldn`t get the saddle out after I had heated the bridge with the saddle still in it and pulled the bridge.Even if it had been glued in ,it should have come out.Of course they were both plastic so I had to be a little careful with the heat.Any thoughts?
James W Bolan
Nashville Tennessee
 Post subject: Re: Stuck saddles
PostPosted: Mon Jul 15, 2013 6:25 pm
I've been having the same luck with a Martin D-18V. I'm building a saddle routing jig to get the job done.
PostPosted: Mon Jul 15, 2013 7:22 pm
I've had some luck grabbing them with a small end nipper and rocking them.
PostPosted: Mon Jul 15, 2013 7:57 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I use my fret puller very carefully at the center and rock them out.
Brian
PostPosted: Tue Jul 16, 2013 11:21 am
apply cold to the saddle. it will shrink away from the bridge. usually a block of aluminum with a saddle sized slot in it that has been dunked in liquid nitrogen, or alcohol and ice, or stuck in the freezer for an hour or so. wear gloves.
easy-peasy.
PostPosted: Tue Jul 16, 2013 3:31 pm
Last Name: Howard
City: Magnolia
State: Delaware
arie wrote:
..... that has been dunked in liquid nitrogen.....
You got that?
Brian
PostPosted: Tue Jul 16, 2013 4:53 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
Liquid nitrogen seems a little extreame, plus being difficult to source. Dry ice in acetone should get you down to about -100° F.
PostPosted: Wed Jul 17, 2013 10:04 am
B. Howard wrote:
You got that?
no, we have it at the day job.
Users browsing this forum: Bing [Bot] and 17 guests
